projects:crazyflie:userguide:index [2013-05-06 19:42] skube [Flying] |
projects:crazyflie:userguide:index [2014-02-18 14:42] tobias [LED indications] |
Line 12: | Line 12: | ||
- | * A controller for input of flight commands (joystick). | + | * A controller for input of flight commands (joystick). Currently |
===== Basic concepts ===== | ===== Basic concepts ===== | ||
Line 20: | Line 20: | ||
==== Flying ==== | ==== Flying ==== | ||
- | The Crazyflie has 4 different controls: | + | The Crazyflie has 4 different controls: |
- | Changing the roll and pitch will make the quadcopter tilt to the sides and thus change the direction that it's moving in. Tiling | + | Changing the roll and pitch will make the quadcopter tilt to the sides and thus change the direction that it's moving in. Tilting |
Line 32: | Line 32: | ||
===== Durability ===== | ===== Durability ===== | ||
- | The Crazyflie is contructed without a separate frame, it uses the PCB as a frame and simply attaches four motors to it. This means that the weight of the platform is very low and on most impacts it simply bounces of objects. If you are unlucky either propellers or motors might break when crashing. If so have a look at our [[projects: | + | The Crazyflie is contructed without a separate frame, it uses the PCB as a frame and simply attaches four motors to it. This means that the weight of the platform is very low and on most impacts it simply bounces of objects. If you are unlucky either propellers or motors might break when crashing. If so have a look at our [[projects: |
====== Basic usage ====== | ====== Basic usage ====== | ||
- | * Power it on by pressing the power button | + | * Power it on by pressing the side-mounted push-button |
* Hold the Crazyflie stable during the start-up, otherwise the sensor tests may not pass. Each motor will quickly turn on to indicate that they are working. | * Hold the Crazyflie stable during the start-up, otherwise the sensor tests may not pass. Each motor will quickly turn on to indicate that they are working. | ||
* Place the Crazyflie on a stable surface (the floor is the best) | * Place the Crazyflie on a stable surface (the floor is the best) | ||
Line 57: | Line 56: | ||
- | - Power button - Powers | + | - Power push-button - Push button to switch the Crazyflie |
- | - Front direction when flying in X configuration | + | - Front direction when flying in X configuration, blue LED is at the tail. |
Line 67: | Line 66: | ||
The Crazyflie has four LEDs mounted, two blue, one red and one green. The two blue LEDs indicate that the system is powered and the red/green shows operation. | The Crazyflie has four LEDs mounted, two blue, one red and one green. The two blue LEDs indicate that the system is powered and the red/green shows operation. | ||
- | During startup | + | When the Crazyflie is powered the two blue LEDs will be lit up and the red/gren LED will blink shortly indicating that the bootloader is executing. After this the firmware will start up. |
+ | During | ||
* Green LED | * Green LED | ||
* **Tests passed:** 5 quick flashes | * **Tests passed:** 5 quick flashes | ||
* Red LED | * Red LED | ||
- | * **Tests failed:** 5 quick flashes | + | * **Tests failed:** 5 quick flashes. This can be caused by too much movement of the Crazyflie when powering it on. Try putting it on a stable surface and try again. |
When USB is connected: | When USB is connected: | ||
Line 91: | Line 92: | ||
All these behaviours can be compile time configured. In the future they might as well be able configurable during runtime using the Crazyflie client. | All these behaviours can be compile time configured. In the future they might as well be able configurable during runtime using the Crazyflie client. | ||
* **Radio communication lost** | * **Radio communication lost** | ||
- | * If the Crazyflie hasn' | + | * If the Crazyflie hasn' |
* **Inactivity shutdown** | * **Inactivity shutdown** | ||
===== The USB Radio dongle ===== | ===== The USB Radio dongle ===== | ||
Line 102: | Line 103: | ||
