projects:crazyflie:userguide:index [2013-05-07 08:23] tobias [Durability] |
projects:crazyflie:userguide:index [2013-05-09 17:21] macke old revision restored |
Line 12: | Line 12: | ||
- | * A controller for input of flight commands (joystick). | + | * A controller for input of flight commands (joystick). Currently |
===== Basic concepts ===== | ===== Basic concepts ===== | ||
Line 20: | Line 20: | ||
==== Flying ==== | ==== Flying ==== | ||
- | The Crazyflie has 4 different controls: | + | The Crazyflie has 4 different controls: |
- | Changing the roll and pitch will make the quadcopter tilt to the sides and thus change the direction that it's moving in. Tiling | + | Changing the roll and pitch will make the quadcopter tilt to the sides and thus change the direction that it's moving in. Tilting |
Line 56: | Line 56: | ||
- | - Power button - Powers | + | - Power button - Push button to switch the Crazyflie |
- | - Front direction when flying in X configuration | + | - Front direction when flying in X configuration, blue LED is at the tail. |
Line 90: | Line 90: | ||
All these behaviours can be compile time configured. In the future they might as well be able configurable during runtime using the Crazyflie client. | All these behaviours can be compile time configured. In the future they might as well be able configurable during runtime using the Crazyflie client. | ||
* **Radio communication lost** | * **Radio communication lost** | ||
- | * If the Crazyflie hasn' | + | * If the Crazyflie hasn' |
* **Inactivity shutdown** | * **Inactivity shutdown** | ||
===== The USB Radio dongle ===== | ===== The USB Radio dongle ===== | ||
Line 101: | Line 101: | ||
