projects:crazyflie:userguide:index [2013-05-07 08:23] tobias [Durability] |
projects:crazyflie:userguide:index [2013-05-14 22:12] tobias [Getting started] |
Line 12: | Line 12: | ||
- | * A controller for input of flight commands (joystick). | + | * A controller for input of flight commands (joystick). Currently |
===== Basic concepts ===== | ===== Basic concepts ===== | ||
Line 20: | Line 20: | ||
==== Flying ==== | ==== Flying ==== | ||
- | The Crazyflie has 4 different controls: | + | The Crazyflie has 4 different controls: |
- | Changing the roll and pitch will make the quadcopter tilt to the sides and thus change the direction that it's moving in. Tiling | + | Changing the roll and pitch will make the quadcopter tilt to the sides and thus change the direction that it's moving in. Tilting |
Line 35: | Line 35: | ||
====== Basic usage ====== | ====== Basic usage ====== | ||
- | * Power it on by pressing the power button | + | * Power it on by pressing the side-mounted push-button |
* Hold the Crazyflie stable during the start-up, otherwise the sensor tests may not pass. Each motor will quickly turn on to indicate that they are working. | * Hold the Crazyflie stable during the start-up, otherwise the sensor tests may not pass. Each motor will quickly turn on to indicate that they are working. | ||
* Place the Crazyflie on a stable surface (the floor is the best) | * Place the Crazyflie on a stable surface (the floor is the best) | ||
Line 56: | Line 56: | ||
- | - Power button - Powers | + | - Power button - Push button to switch the Crazyflie |
- | - Front direction when flying in X configuration | + | - Front direction when flying in X configuration, blue LED is at the tail. |
Line 90: | Line 90: | ||
All these behaviours can be compile time configured. In the future they might as well be able configurable during runtime using the Crazyflie client. | All these behaviours can be compile time configured. In the future they might as well be able configurable during runtime using the Crazyflie client. | ||
* **Radio communication lost** | * **Radio communication lost** | ||
- | * If the Crazyflie hasn' | + | * If the Crazyflie hasn' |
* **Inactivity shutdown** | * **Inactivity shutdown** | ||
===== The USB Radio dongle ===== | ===== The USB Radio dongle ===== | ||
Line 101: | Line 101: | ||
