projects:crazyflie:userguide:index [2013-05-09 16:23] macke [The Crazyflie] |
projects:crazyflie:userguide:index [2013-10-01 09:53] tobias [LED indications] |
Line 35: | Line 35: | ||
====== Basic usage ====== | ====== Basic usage ====== | ||
- | * Power it on by pressing the power button | + | * Power it on by pressing the side-mounted push-button |
* Hold the Crazyflie stable during the start-up, otherwise the sensor tests may not pass. Each motor will quickly turn on to indicate that they are working. | * Hold the Crazyflie stable during the start-up, otherwise the sensor tests may not pass. Each motor will quickly turn on to indicate that they are working. | ||
* Place the Crazyflie on a stable surface (the floor is the best) | * Place the Crazyflie on a stable surface (the floor is the best) | ||
Line 56: | Line 56: | ||
- | - Power button - Powers | + | - Power push-button - Push button to switch the Crazyflie |
- Front direction when flying in X configuration, | - Front direction when flying in X configuration, | ||
Line 66: | Line 66: | ||
The Crazyflie has four LEDs mounted, two blue, one red and one green. The two blue LEDs indicate that the system is powered and the red/green shows operation. | The Crazyflie has four LEDs mounted, two blue, one red and one green. The two blue LEDs indicate that the system is powered and the red/green shows operation. | ||
- | During startup | + | When the Crazyflie is powered the two blue LEDs will be lit up and the red/gren LED will blink shortly indicating that the bootloader is executing. After this the firmware will start up. |
+ | During | ||
* Green LED | * Green LED | ||
* **Tests passed:** 5 quick flashes | * **Tests passed:** 5 quick flashes | ||
* Red LED | * Red LED | ||
- | * **Tests failed:** 5 quick flashes | + | * **Tests failed:** 5 quick flashes. This can be caused by too much movement of the Crazyflie when powering it on. If you get it place it on a stable surface and try again. |
When USB is connected: | When USB is connected: | ||
Line 101: | Line 103: | ||
