projects:crazyflie:userguide:index [2013-05-07 14:02] skube [Flying] |
projects:crazyflie:userguide:index [2021-06-24 16:53] kimberly |
====== Introduction ====== | ====== Introduction ====== | ||
===== What is the Crazyfile Nano Quadcopter used for ===== | ===== What is the Crazyfile Nano Quadcopter used for ===== | ||
Line 11: | Line 14: | ||
- | * [[projects:crazyflie:pc_utils:qt_ui|A PC side application for controlling the quadcopter]] | + | * [[doc:crazyflie:client:pycfclient: |
- | * A controller for input of flight commands (joystick). | + | * A controller for input of flight commands (joystick). Currently |
===== Basic concepts ===== | ===== Basic concepts ===== | ||
Line 20: | Line 23: | ||
==== Flying ==== | ==== Flying ==== | ||
- | The Crazyflie has 4 different controls: | + | The Crazyflie has 4 different controls: |
- | Changing the roll and pitch will make the quadcopter tilt to the sides and thus change the direction that it's moving in. Tilting the quadcopter forward will make it go forward and the same applies for every other direction. | + | Changing the roll and pitch will make the quadcopter tilt to the sides and thus change the direction that it's moving in. Tilting the quadcopter forward will make it go forward and the same applies for every other direction. |
Line 35: | Line 38: | ||
====== Basic usage ====== | ====== Basic usage ====== | ||
- | * Power it on by pressing the power button | + | * Power it on by pressing the side-mounted push-button |
* Hold the Crazyflie stable during the start-up, otherwise the sensor tests may not pass. Each motor will quickly turn on to indicate that they are working. | * Hold the Crazyflie stable during the start-up, otherwise the sensor tests may not pass. Each motor will quickly turn on to indicate that they are working. | ||
* Place the Crazyflie on a stable surface (the floor is the best) | * Place the Crazyflie on a stable surface (the floor is the best) | ||
* Wait until the red LED shows that the sensors are calibrated by increasing the blink rate from 1Hz to 2Hz. | * Wait until the red LED shows that the sensors are calibrated by increasing the blink rate from 1Hz to 2Hz. | ||
- | * Connect to the quadcopter using the [[projects:crazyflie:pc_utils:qt_ui|computer application]] | + | * Connect to the quadcopter using the [[doc:crazyflie:client:pycfclient: |
* The green LED will now start flashing indicating that the radio communication is working | * The green LED will now start flashing indicating that the radio communication is working | ||
* Use the controller to control the movement of the quadcopter | * Use the controller to control the movement of the quadcopter | ||
Line 56: | Line 59: | ||
- | - Power button - Powers | + | - Power push-button - Push button to switch the Crazyflie |
- | - Front direction when flying in X configuration | + | - Front direction when flying in X configuration, blue LED is at the tail. |
Line 66: | Line 69: | ||
The Crazyflie has four LEDs mounted, two blue, one red and one green. The two blue LEDs indicate that the system is powered and the red/green shows operation. | The Crazyflie has four LEDs mounted, two blue, one red and one green. The two blue LEDs indicate that the system is powered and the red/green shows operation. | ||
- | During startup | + | When the Crazyflie is powered the two blue LEDs will be lit up and the red/gren LED will blink shortly indicating that the bootloader is executing. After this the firmware will start up. |
+ | During | ||
* Green LED | * Green LED | ||
* **Tests passed:** 5 quick flashes | * **Tests passed:** 5 quick flashes | ||
* Red LED | * Red LED | ||
- | * **Tests failed:** 5 quick flashes | + | * **Tests failed:** 5 quick flashes. This can be caused by too much movement of the Crazyflie when powering it on. Try putting it on a stable surface and try again. |
When USB is connected: | When USB is connected: | ||
Line 90: | Line 95: | ||
All these behaviours can be compile time configured. In the future they might as well be able configurable during runtime using the Crazyflie client. | All these behaviours can be compile time configured. In the future they might as well be able configurable during runtime using the Crazyflie client. | ||
* **Radio communication lost** | * **Radio communication lost** | ||
- | * If the Crazyflie hasn' | + | * If the Crazyflie hasn' |
* **Inactivity shutdown** | * **Inactivity shutdown** | ||
===== The USB Radio dongle ===== | ===== The USB Radio dongle ===== | ||
Line 101: | Line 106: | ||
