projects:crazyflie:userguide:index [2013-05-07 14:22] skube [Firmware behaviour] |
projects:crazyflie:userguide:index [2021-06-24 16:53] kimberly |
====== Introduction ====== | ====== Introduction ====== | ||
===== What is the Crazyfile Nano Quadcopter used for ===== | ===== What is the Crazyfile Nano Quadcopter used for ===== | ||
Line 11: | Line 14: | ||
- | * [[projects:crazyflie:pc_utils:qt_ui|A PC side application for controlling the quadcopter]] | + | * [[doc:crazyflie:client:pycfclient: |
- | * A controller for input of flight commands (joystick). | + | * A controller for input of flight commands (joystick). Currently |
===== Basic concepts ===== | ===== Basic concepts ===== | ||
Line 35: | Line 38: | ||
====== Basic usage ====== | ====== Basic usage ====== | ||
- | * Power it on by pressing the power button | + | * Power it on by pressing the side-mounted push-button |
* Hold the Crazyflie stable during the start-up, otherwise the sensor tests may not pass. Each motor will quickly turn on to indicate that they are working. | * Hold the Crazyflie stable during the start-up, otherwise the sensor tests may not pass. Each motor will quickly turn on to indicate that they are working. | ||
* Place the Crazyflie on a stable surface (the floor is the best) | * Place the Crazyflie on a stable surface (the floor is the best) | ||
* Wait until the red LED shows that the sensors are calibrated by increasing the blink rate from 1Hz to 2Hz. | * Wait until the red LED shows that the sensors are calibrated by increasing the blink rate from 1Hz to 2Hz. | ||
- | * Connect to the quadcopter using the [[projects:crazyflie:pc_utils:qt_ui|computer application]] | + | * Connect to the quadcopter using the [[doc:crazyflie:client:pycfclient: |
* The green LED will now start flashing indicating that the radio communication is working | * The green LED will now start flashing indicating that the radio communication is working | ||
* Use the controller to control the movement of the quadcopter | * Use the controller to control the movement of the quadcopter | ||
Line 56: | Line 59: | ||
- | - Power button - Powers | + | - Power push-button - Push button to switch the Crazyflie |
- | - Front direction when flying in X configuration | + | - Front direction when flying in X configuration, blue LED is at the tail. |
Line 66: | Line 69: | ||
The Crazyflie has four LEDs mounted, two blue, one red and one green. The two blue LEDs indicate that the system is powered and the red/green shows operation. | The Crazyflie has four LEDs mounted, two blue, one red and one green. The two blue LEDs indicate that the system is powered and the red/green shows operation. | ||
- | During startup | + | When the Crazyflie is powered the two blue LEDs will be lit up and the red/gren LED will blink shortly indicating that the bootloader is executing. After this the firmware will start up. |
+ | During | ||
* Green LED | * Green LED | ||
* **Tests passed:** 5 quick flashes | * **Tests passed:** 5 quick flashes | ||
* Red LED | * Red LED | ||
- | * **Tests failed:** 5 quick flashes | + | * **Tests failed:** 5 quick flashes. This can be caused by too much movement of the Crazyflie when powering it on. Try putting it on a stable surface and try again. |
When USB is connected: | When USB is connected: | ||
Line 101: | Line 106: | ||
