User Tools
Site Tools
projects:crazyflie:userguide:index
Differences
Link to this comparison view
Next revision
Previous revision
projects:crazyflie:userguide:index [2013-05-07 14:22]
skube [Firmware behaviour]
projects:crazyflie:userguide:index [2021-06-24 16:53] (current)
Line 1: Line 1:
 +</WRAP>
 ====== Introduction ====== ====== Introduction ======
 ===== What is the Crazyfile Nano Quadcopter used for ===== ===== What is the Crazyfile Nano Quadcopter used for =====
Line 11: Line 14:
   * [[projects:crazyflie:index|A Crazyflie quadcopter]] :-)   * [[projects:crazyflie:index|A Crazyflie quadcopter]] :-)
   * [[projects:crazyradio:index|A Crazyradio USB dongle]]   * [[projects:crazyradio:index|A Crazyradio USB dongle]]
-  * [[projects:crazyflie:pc_utils:qt_ui|A PC side application for controlling the quadcopter]] +  * [[doc:crazyflie:client:pycfclient:index|A PC side application for controlling the quadcopter]]
-  * A controller for input of flight commands (joystick). **Currently only PlayStation compatible input devices are well supported.**+  * A controller for input of flight commands (joystick). Currently Playstation and Xbox 360 controllers are supported out of the box, but any controller with at least 4 analog axis can be configured and used. Se the [[projects:crazyflie:pc_utils:inputdevices|input-device]] page for more information.
 ===== Basic concepts ===== ===== Basic concepts =====
Line 35: Line 38:
 ====== Basic usage ====== ====== Basic usage ======
 ===== Getting started ===== ===== Getting started =====
-  * Power it on by pressing the power button+  * Power it on by pressing the side-mounted push-button
   * Hold the Crazyflie stable during the start-up, otherwise the sensor tests may not pass. Each motor will quickly turn on to indicate that they are working.   * Hold the Crazyflie stable during the start-up, otherwise the sensor tests may not pass. Each motor will quickly turn on to indicate that they are working.
   * Place the Crazyflie on a stable surface (the floor is the best)   * Place the Crazyflie on a stable surface (the floor is the best)
   * Wait until the red LED shows that the sensors are calibrated by increasing the blink rate from 1Hz to 2Hz.   * Wait until the red LED shows that the sensors are calibrated by increasing the blink rate from 1Hz to 2Hz.
-  * Connect to the quadcopter using the [[projects:crazyflie:pc_utils:qt_ui|computer application]]+  * Connect to the quadcopter using the [[doc:crazyflie:client:pycfclient:index|computer application]]
   * The green LED will now start flashing indicating that the radio communication is working   * The green LED will now start flashing indicating that the radio communication is working
   * Use the controller to control the movement of the quadcopter   * Use the controller to control the movement of the quadcopter
Line 56: Line 59:
   - Blue LED - Shows power on status   - Blue LED - Shows power on status
   - Expansion - Can be used to expand functionality by adding hardware   - Expansion - Can be used to expand functionality by adding hardware
-  - Power button - Powers on/off+  - Power push-button - Push button to switch the Crazyflie on/off (**Note that this is a push button, not a sliding button**)
   - Front direction when flying in normal configuration   - Front direction when flying in normal configuration
-  - Front direction when flying in X configuration+  - Front direction when flying in X configuration, blue LED is at the tail.
Line 66: Line 69:
 The Crazyflie has four LEDs mounted, two blue, one red and one green. The two blue LEDs indicate that the system is powered and the red/green shows operation. The Crazyflie has four LEDs mounted, two blue, one red and one green. The two blue LEDs indicate that the system is powered and the red/green shows operation.
-During startup+When the Crazyflie is powered the two blue LEDs will be lit up and the red/gren LED will blink shortly indicating that the bootloader is executing. After this the firmware will start up.
 +During firmware startup:
   * Green LED   * Green LED
     * **Tests passed:** 5 quick flashes     * **Tests passed:** 5 quick flashes
   * Red LED   * Red LED
-    * **Tests failed:** 5 quick flashes+    * **Tests failed:** 5 quick flashes. This can be caused by too much movement of the Crazyflie when powering it on. Try putting it on a stable surface and try again.
 When USB is connected: When USB is connected:
Line 101: Line 106:
   - Programming/PPM interface - Used for programming and interfacing with a RC remote   - Programming/PPM interface - Used for programming and interfacing with a RC remote
   - Antenna connector - Connector for antenna   - Antenna connector - Connector for antenna
-  - Red LED - Toggles when data is no able to be sent to the quadcopter+  - Red LED - Toggles when data is now able to be sent to the quadcopter
   - Green LED - Toggles when data is successfully send to the quadcopter    - Green LED - Toggles when data is successfully send to the quadcopter
projects/crazyflie/userguide/index.1367929342.txt.gz · Last modified: 2015-07-15 16:30 (external edit)
