User Tools
Site Tools
projects:crazyflie:userguide:index
Differences
Link to this comparison view
Next revision
Previous revision
projects:crazyflie:userguide:index [2014-02-18 14:42]
tobias [LED indications]
projects:crazyflie:userguide:index [2021-06-24 16:53] (current)
Line 1: Line 1:
 +</WRAP>
 ====== Introduction ====== ====== Introduction ======
 ===== What is the Crazyfile Nano Quadcopter used for ===== ===== What is the Crazyfile Nano Quadcopter used for =====
Line 11: Line 14:
   * [[projects:crazyflie:index|A Crazyflie quadcopter]] :-)   * [[projects:crazyflie:index|A Crazyflie quadcopter]] :-)
   * [[projects:crazyradio:index|A Crazyradio USB dongle]]   * [[projects:crazyradio:index|A Crazyradio USB dongle]]
-  * [[projects:crazyflie:pc_utils:qt_ui|A PC side application for controlling the quadcopter]]+  * [[doc:crazyflie:client:pycfclient:index|A PC side application for controlling the quadcopter]]
   * A controller for input of flight commands (joystick). Currently Playstation 3 and Xbox 360 controllers are supported out of the box, but any controller with at least 4 analog axis can be configured and used. Se the [[projects:crazyflie:pc_utils:inputdevices|input-device]] page for more information.   * A controller for input of flight commands (joystick). Currently Playstation 3 and Xbox 360 controllers are supported out of the box, but any controller with at least 4 analog axis can be configured and used. Se the [[projects:crazyflie:pc_utils:inputdevices|input-device]] page for more information.
Line 39: Line 42:
   * Place the Crazyflie on a stable surface (the floor is the best)   * Place the Crazyflie on a stable surface (the floor is the best)
   * Wait until the red LED shows that the sensors are calibrated by increasing the blink rate from 1Hz to 2Hz.   * Wait until the red LED shows that the sensors are calibrated by increasing the blink rate from 1Hz to 2Hz.
-  * Connect to the quadcopter using the [[projects:crazyflie:pc_utils:qt_ui|computer application]]+  * Connect to the quadcopter using the [[doc:crazyflie:client:pycfclient:index|computer application]]
   * The green LED will now start flashing indicating that the radio communication is working   * The green LED will now start flashing indicating that the radio communication is working
   * Use the controller to control the movement of the quadcopter   * Use the controller to control the movement of the quadcopter
projects/crazyflie/userguide/index.1392730952.txt.gz · Last modified: 2015-07-15 16:30 (external edit)
