projects:crazyflie:userguide:troubleshooting [2012-03-06 10:51] macke |
projects:crazyflie:userguide:troubleshooting [2015-03-01 23:40] fred |
- | ====== Intro ====== | ||
- | ====== Troubleshooting ====== | ||
- | ==== When I try to connect to the quadcopter I get an error and the red LED is not blinking ==== | ||
- | This is almost always due to a missmatch in radio channel. Make sure to have the same radio channel for the quadcopter and the computer application. | ||
- | ==== When I try to take off there seems to be no lift on one/or more motors ==== | ||
- | Most of the time this is either due to the fact that there' | ||
- | If neither helps check that the [[projects: | ||
- | ==== The radio reception is really bad ==== | ||
- | If the linkspeed is set to 2Mbit switch it to 250Kbps. This will normally increase/ | ||
