projects:crazyflie:userguide:troubleshooting [2012-11-15 21:06] arnaud [The radio reception is really bad] |
projects:crazyflie:userguide:troubleshooting [2015-03-01 23:40] fred |
- | ====== Intro ====== | ||
- | Below are some common problems/ | ||
- | ====== Troubleshooting ====== | ||
- | ==== When I try to connect to the quadcopter I get an error and the green LED is not flashing, indicating radio link up ==== | ||
- | This is probably due to a bad radio-connection (using same channel as WiFi?) or it can be due to that the Crazyflie has been pluged/ | ||
- | ==== When I try to take off there seems to be no lift on one/or more motors ==== | ||
- | Most of the time this is either due to the fact that there' | ||
- | If neither helps check that the [[projects: | ||
- | ==== The radio reception is really bad ==== | ||
- | If the linkspeed is set to 2Mbit switch it to 250Kbps. This will normally increase/ | ||
- | ==== I have broken motors/ | ||
- | As soon as the quadcopters are available for purchase we will also have spare part kits available containing propellers, motors and motor mounts. | ||
