projects:crazyradio:dev_env [2012-02-20 22:01] arnaud |
projects:crazyradio:dev_env [2013-12-03 09:14] macke |
Line 4: | Line 4: | ||
As of version 0.31 the dongle program must be compiled with an SDCC version < 3.0 because of some register declaration are broken with SDCC 3. | As of version 0.31 the dongle program must be compiled with an SDCC version < 3.0 because of some register declaration are broken with SDCC 3. | ||
+ | From version 0.4 the dongle firmware has been ported to SDCC 3.0. So it can be compiled out of the box without the need of an old SDCC version. | ||
===== Compilation ===== | ===== Compilation ===== | ||
Line 9: | Line 11: | ||
These instruction works on a recent (as of 2012-02) linux distribution: | These instruction works on a recent (as of 2012-02) linux distribution: | ||
- | * Download SDCC 2.9 http:// | + | * Download SDCC 3.2 http:// |
* Extract SDCC in your home folder | * Extract SDCC in your home folder | ||
* The radio can be compiled as follow: | * The radio can be compiled as follow: | ||
Line 27: | Line 29: | ||
- | ===== Documentations | + | ===== Documentation |
