projects:crazyradio:dev_env [2015-07-15 16:31] 127.0.0.1 external edit |
projects:crazyradio:dev_env [2019-09-05 14:53] kimberly |
- | ====== Crazyradio development environment ====== | + | <WRAP center round important 60%> |
- | The crazyradio dongle is based on a Nordic semiconductor nRF24LU1 chip. This chip contains a 8051-compatible microcontroller and is programmed using the SDCC compiler. | + | [[ |
+ | https://www.bitcraze.io/ | ||
- | As of version 0.31 the dongle program must be compiled with an SDCC version | + | </WRAP> |
- | From version 0.4 the dongle firmware has been ported to SDCC 3.0. So it can be compiled out of the box without the need of an old SDCC version. | ||
- | ===== Compilation | + | ====== Crazyradio development environment ====== |
- | These instruction works on a recent (as of 2012-02) linux distribution: | + | |
- | * Download SDCC 3.2 http:// | + | The crazyradio dongle is based on a Nordic semiconductor nRF24LU1 chip. This chip contains a 8051-compatible microcontroller and is programmed using the SDCC compiler. For compiling instruction see the project |
- | * Extract SDCC in your home folder | + | |
- | * The radio can be compiled as follow: | + | |
- | <code bash> | + | |
- | [crazyradio]$ export SDCC=~/ | + | |
- | [crazyradio]$ make | + | |
- | mkdir -p bin | + | |
- | /home/arnaud/ | + | |
- | /home/ | + | |
- | objcopy -I ihex bin/ | + | |
- | [crazyradio]$ | + | |
- | * //cradio.ihx// can be programmed with the USB bootloader. // | + | |
===== Documentation ===== | ===== Documentation ===== |
