projects:crazyradio:dev_env [2012-02-20 21:59] arnaud created |
projects:crazyradio:dev_env [2020-05-12 14:12] (current) kimberly |
| - | ====== Crazyradio development environment ====== | + | <WRAP center round important 60%> |
| - | The crazyradio dongle is based on a Nordic semiconductor nRF24LU1 chip. This chip contains a 8051-compatible microcontroller and is programmed using the SDCC compiler. | ||
| - | As of version 0.31 the dongle program must be compiled with an SDCC version < 3.0 because of some register declaration are broken with SDCC 3. | + | ====== Crazyradio development environment ====== |
| - | ===== Compilation ===== | + | The crazyradio dongle is based on a Nordic semiconductor nRF24LU1 chip. This chip contains a 8051-compatible microcontroller and is programmed using the SDCC compiler. For compiling instruction see the project [[https:// |
| - | These instruction works on a recent (as of 2012-02) linux distribution: | + | ===== Documentation ===== |
| + | {{:projects: | ||
| - | * Download SDCC 2.9 http:// | ||
| - | * Extract SDCC in your home folder | ||
| - | * The radio can be compiled as follow: | ||
| - | <code bash> | ||
| - | [crazyradio]$ export SDCC=~/ | ||
| - | [crazyradio]$ make | ||
| - | mkdir -p bin | ||
| - | objcopy -I ihex bin/ | ||
| - | [crazyradio]$ | ||
