projects:crazyradio:index [2012-09-17 14:10] arnaud |
projects:crazyradio:index [2014-01-30 10:01] arnaud [User guide] |
+ | The Crazyradio is a 2.4 GHz radio USB dongle. Currently it's only used to communicate with the [[projects: | ||
- | | + | **Features** |
- | * [[projects: | + | * Based on the [[http:// |
+ | * USB bootloader enables firmware upgrades via USB | ||
+ | * Can be used as stand-alone module with RC controller via expansion header. Supports 12V PPM input and power supply. **Note:** There' | ||
+ | * Comes with GPLv3 firmware developed fully by Bitcraze from datasheet and a build environment that allows you to develop your own firmware | ||
+ | * Programmable via SPI using expansion header | ||
+ | ====== User guide ====== | ||
+ | * [[projects: | ||
+ | ====== Hardware ====== | ||
+ | * [[projects: |
