projects:crazyradio:index [2011-06-02 18:19] arnaud created |
projects:crazyradio:index [2021-06-24 16:15] (current) kimberly |
| - | ====== CrazyRadio ====== | + | <WRAP center round important 60%> |
| + | ====== Crazyradio ====== | ||
| + | The Crazyradio is a 2.4 GHz radio USB dongle. Currently it's only used to communicate with the [[projects: | ||
| + | **Features** | ||
| + | * Based on the [[http:// | ||
| + | * USB bootloader enables firmware upgrades via USB | ||
| + | * Can be used as stand-alone module with RC controller via expansion header. Supports 12V PPM input and power supply. **Note:** There' | ||
| + | * Comes with GPLv3 firmware developed fully by Bitcraze from datasheet and a build environment that allows you to develop your own firmware | ||
| + | * Programmable via SPI using expansion header | ||
| + | ====== User guide ====== | ||
| + | * [[doc: | ||
| + | * [[doc: | ||
| + | * [[doc: | ||
| + | * [[projects: | ||
| + | ====== Development ====== | ||
| + | * [[doc: | ||
| + | ====== Hardware ====== | ||
