projects:crazyradio:index [2011-06-02 18:19] arnaud created |
projects:crazyradio:index [2021-06-24 16:15] kimberly |
- | ====== CrazyRadio ====== | + | <WRAP center round important 60%> |
+ | ====== Crazyradio ====== | ||
+ | The Crazyradio is a 2.4 GHz radio USB dongle. Currently it's only used to communicate with the [[projects: | ||
+ | **Features** | ||
+ | * Based on the [[http:// | ||
+ | * USB bootloader enables firmware upgrades via USB | ||
+ | * Can be used as stand-alone module with RC controller via expansion header. Supports 12V PPM input and power supply. **Note:** There' | ||
+ | * Comes with GPLv3 firmware developed fully by Bitcraze from datasheet and a build environment that allows you to develop your own firmware | ||
+ | * Programmable via SPI using expansion header | ||
+ | ====== User guide ====== | ||
+ | * [[doc: | ||
+ | * [[doc: | ||
+ | * [[doc: | ||
+ | * [[projects: | ||
+ | * [[doc: | ||
+ | ====== Hardware ====== | ||
+ | * [[projects: |
