projects:crazyradio:programming [2013-05-19 12:17] macke |
projects:crazyradio:programming [2013-08-08 09:18] macke [Step-by-step upgrade using the Bitcraze VM] |
Line 50: | Line 50: | ||
Bootloader started | Bootloader started | ||
- | * Once the bootloader is started the Crazyradio dongle will dissapear ad a new device named **nRF24LU1P-F32 BOOT LDR** will appear. Pass this to the VM. | + | * Once the bootloader is started the Crazyradio dongle will dissapear ad a new device named **Nordic Semiconductor |
* Run the following command: | * Run the following command: | ||
- | > python usbtools/ | + | > python usbtools/ |
Found nRF24LU1 bootloader version 18.0 | Found nRF24LU1 bootloader version 18.0 | ||
Flashing: | Flashing: | ||
Line 59: | Line 59: | ||
Flashing done! | Flashing done! | ||
Verifying: | Verifying: | ||
- | Reading cradio-0.51.bin... | + | Reading cradio-0.52.bin... |
- | Reading | + | Reading |
Verification succeded! | Verification succeded! | ||
* If you see **Verification succeded** then unplug the dongle and re-insert it again. If you do not see this message, but instead some error. Do **NOT** unplug the dongle, try to reflash the firmware instead. | * If you see **Verification succeded** then unplug the dongle and re-insert it again. If you do not see this message, but instead some error. Do **NOT** unplug the dongle, try to reflash the firmware instead. |
