projects:crazyradio:programming [2013-05-19 17:31] macke |
projects:crazyradio:programming [2015-07-15 16:31] 127.0.0.1 external edit |
Line 26: | Line 26: | ||
> cd crazyradio-firmware | > cd crazyradio-firmware | ||
- | > python usbtools/ | + | > python usbtools/ |
Found nRF24LU1 bootloader version 18.0 | Found nRF24LU1 bootloader version 18.0 | ||
Flashing: | Flashing: | ||
- | Flashing | + | Flashing |
Flashing done! | Flashing done! | ||
Verifying: | Verifying: | ||
- | Reading cradio-0.51.bin... | + | Reading cradio-pa-0.53.bin... |
- | Reading | + | Reading |
Verification succeded! | Verification succeded! | ||
===== Step-by-step upgrade using the Bitcraze VM ===== | ===== Step-by-step upgrade using the Bitcraze VM ===== | ||
- | Below is a short guide with step-by-step instructions on how to upgrade the Crazyradio with the latest firmware using the [[projects: | + | Below is a short guide with step-by-step instructions on how to upgrade the Crazyradio with the latest firmware using the [[projects: |
- | * Start up the VM and download the latest firmware from [[https://bitbucket.org/ | + | * Start up the VM and download the latest firmware from [[https://github.com/ |
* Open up a terminal | * Open up a terminal | ||
* Insert the Crazyradio and pass it to the VM | * Insert the Crazyradio and pass it to the VM | ||
Line 50: | Line 50: | ||
Bootloader started | Bootloader started | ||
- | * Once the bootloader is started the Crazyradio dongle will dissapear ad a new device named **nRF24LU1P-F32 BOOT LDR** will appear. If you do not have a filter set up for the bootloader in the VM then script will say that it failed. This is ok. Pass the bootloader device into the VM and continue. | + | * Once the bootloader is started the Crazyradio dongle will dissapear ad a new device named **Nordic Semiconductor |
* Run the following command: | * Run the following command: | ||
* If you see **Verification succeded** then unplug the dongle and re-insert it again. If you do not see this message, but instead some error. Do **NOT** unplug the dongle, try to reflash the firmware instead. | * If you see **Verification succeded** then unplug the dongle and re-insert it again. If you do not see this message, but instead some error. Do **NOT** unplug the dongle, try to reflash the firmware instead. | ||
+ | ===== Check your firmware version ===== | ||
+ | Run the following command: | ||
+ | > lsusb -d 1915:7777 -v | grep bcdDevice | ||
+ | This should return the version (e.g. " |
