projects:crazyradio:spi_programming [2013-06-05 13:35] macke |
projects:crazyradio:spi_programming [2019-09-05 14:55] kimberly |
+ | https:// | ||
====== Crazyradio SPI programming ====== | ====== Crazyradio SPI programming ====== | ||
Line 64: | Line 73: | ||
===== Using BusPirate ===== | ===== Using BusPirate ===== | ||
+ | <WRAP center round alert> | ||
+ | **WARNING** | ||
+ | This script will mass erase the nRF24 chip so it will erase the bootloader. Make sure you have a backup of the bootloader before using this script. | ||
+ | Unless you are absolutely sure of what you are doing, **do not use this script**. | ||
It's possible to re-program the Crazyradio using a BusPirate and [[https:// | It's possible to re-program the Crazyradio using a BusPirate and [[https:// | ||
