projects:crazyradio:spi_programming [2013-05-27 20:18] arnaud [Usage] |
projects:crazyradio:spi_programming [2020-05-12 14:14] (current) kimberly |
| ====== Crazyradio SPI programming ====== | ====== Crazyradio SPI programming ====== | ||
| Line 63: | Line 67: | ||
| + | ===== Using BusPirate ===== | ||
| + | <WRAP center round alert> | ||
| + | **WARNING** | ||
| + | This script will mass erase the nRF24 chip so it will erase the bootloader. Make sure you have a backup of the bootloader before using this script. | ||
| + | Unless you are absolutely sure of what you are doing, **do not use this script**. | ||
| + | It's possible to re-program the Crazyradio using a BusPirate and [[https:// | ||
| + | Couple of caveats: | ||
| + | * Tested only on OS X. Should work on Linux without modification, | ||
| + | * It's very slow (~5 minutes to flash the entire .bin file). I deemed this acceptable as this script is for emergency recovery only. I can make it faster if necessary. | ||
| + | Prerequisites: | ||
| + | * A Bus Pirate (you should know where to get one of these, if you don't already have one). | ||
| + | * perl and either Device:: | ||
| + | * Some jumper wires to connect the SPI lines on the radio to the ones on the Bus Pirate. | ||
| + | Instructions: | ||
| + | - Solder a 2x5 pin header onto the programming port of the crazyradio. There' | ||
| + | - Connect the crazyradio to your Bus Pirate using the table below (also noted in the script and readme on git) < | ||
| + | Bus Pirate | ||
| + | MOSI () -> MOSI (6) | ||
| + | MISO () -> MISO (8) | ||
| + | SCK () -> SCK (4) | ||
| + | CS | ||
| + | AUX () -> PROG (2) | ||
| + | 3V3 () -> 3V3 (5) | ||
| + | GND () -> GND (9) | ||
| + | - Run the script: perl ./ | ||
| + | - Wait till you see lots of hex addresses crawling up your screen. Your device is programming. | ||
| + | - Go make a sandwich or have a beer (or both). | ||
