projects:dockerbuilderimage:index [2015-12-28 16:57] kristoffer |
projects:dockerbuilderimage:index [2016-03-30 09:32] kristoffer |
- | We have created | + | The toolbelt is a utility |
- | The builder image is used when building the project on our CI server at [[https:// | + | The docker images that are used when building |
- | The image is available | + | The builder images are also used when building the project on our CI server |
- | Documentation | + | The source code for the toolbelt can be found on [[https:// |
+ | ===== Installation and usage ===== | ||
+ | Instructions on how to install and use the toolbelt are available in the [[https:// | ||
