projects:dockerbuilderimage:index [2016-10-31 15:11] kristoffer [The toolbelt and Docker Builder Images] |
projects:dockerbuilderimage:index [2021-06-24 16:16] (current) kimberly |
====== The toolbelt and Docker Builder Images ====== | ====== The toolbelt and Docker Builder Images ====== | ||
The toolbelt is a utility to enable builds of software modules without installing toolchains, frameworks and so on. In some respects it is an alternative to the VM, even though it is not as complete. The toolbelt requires close to no installation and uses [[https:// | The toolbelt is a utility to enable builds of software modules without installing toolchains, frameworks and so on. In some respects it is an alternative to the VM, even though it is not as complete. The toolbelt requires close to no installation and uses [[https:// | ||
- | The docker images that are used when building modules are called builders and contain´ | + | The docker images that are used when building modules are called builders and contain |
The builder images are also used when building the project on our CI server at [[https:// | The builder images are also used when building the project on our CI server at [[https:// | ||
Line 11: | Line 15: | ||
Instructions on how to install and use the toolbelt are available in the [[https:// | Instructions on how to install and use the toolbelt are available in the [[https:// | ||
