projects:lps:index [2016-02-04 12:02] macke |
projects:lps:index [2019-01-29 15:08] macke [Hardware description] |
- | <WRAP center round info> | + | ====== Loco Positioning System ====== |
- | //**Alpha production**// | + | |
- | Currently this product is only available as part if our [[https:// | + | |
- | ====== System overview ====== | + | The loco positioning system (LPS) project is a set of hardware and software designed to implement a local positioning system |
- | The local positioning system is based on the [[http:// | + | |
- | <WRAP group> | + | ===== Hardware description ===== |
- | <WRAP half column> | + | The hardware consists |
- | Our testsystem uses the following components: | + | * [[projects: |
- | * 6 anchors (with power cables) using < | + | * [[projects: |
- | * 1 deck | + | * [[projects:lps: |
- | * Computer running [[http:// | + | |
- | * Crazyflie client with ZMQ to mix manual and automatic control | + | |
- | <WRAP half column> | + | |
- | Here's a video of the current state (January 2016). | + | |
- | {{youtube> | + | |
- | ====== Hardware description | + | |
- | The hardware consists | + | |
- | ===== LPS Node ===== | + | |
- | {{:projects: | + | |
- | <WRAP group> | + | |
- | Connects and buttons: | + | |
- | - **uUSB**: Used to power board (and will have command-line interface) | + | |
- | - **DC-jack**: | + | |
- | - **Terminal**: | + | |
- | - **Reset**: Reset the board | + | |
- | - **Exp connector**: | + | |
- | - **USR & DFU**: If pressed and held during reset or power on this will put the board into DFU bootloader mode. When the system is up and running the button is still unused, but could be used to trigger functionality in the firmware. | + | |
- | - **FTDI**: Connector designed for the FTDI serial-to-USB cable (TTL-232R-3V3). Except for getting a serial console for debugging it can also be used to power the board. Note that signals are 3V3 and power is 5V. | + | |
- | MCU controlled LEDs: | + | |
- | * **POWER**: On when board is powered | + | |
- | * **RANGING**: | + | |
- | * **SYNC**: TDB | + | |
- | * **MODE**: On in Anchor mode, off in Tag mode and blinking in Sniffer mode | + | |
- | DWM1000 controlled LEDs: | + | |
- | * **TX**: Transmitting | + | |
- | * **RX**: Receiving | + | |
- | * **SFD**: Received packet timestamp | + | |
- | * **RXOK**: Packet received without error | + | |
- | ===== DWM deck ===== | + | |
- | TBD | + | |
- | ====== Firmware ====== | + | |
- | ===== DWM Node ===== | + | |
- | ==== Building and flashing ==== | + | |
- | Building and flashing is described in the [[https:// | + | |
- | Flashing via DFU requires [[http:// | + | |
- | The firmware for the DWM deck is included in the Crazyflie 2.0 firmware build (recent) and activated when the deck is attached. The deck contains a small memory that holds the address of the board as well as the addresses of the anchors it will use for ranging. | + | |
- | More information on building | + | |
- | ====== ROS ====== | + | |
