projects:lps:index [2016-05-25 16:02] arnaud |
projects:lps:index [2019-01-29 16:56] macke [Hardware description] |
====== Loco Positioning System ====== | ====== Loco Positioning System ====== | ||
- | <WRAP center round info> | ||
- | //**Early access**// | ||
- | Currently this product line is in [[https:// | ||
The loco positioning system (LPS) project is a set of hardware and software designed to implement a local positioning system (LPS). The hardware is based on the Decawave DW1000 chip. For more information about the system see the [[doc: | The loco positioning system (LPS) project is a set of hardware and software designed to implement a local positioning system (LPS). The hardware is based on the Decawave DW1000 chip. For more information about the system see the [[doc: | ||
===== Hardware description ===== | ===== Hardware description ===== | ||
- | The hardware consists | + | The hardware consists |
+ | * [[projects: | ||
