User Tools
Site Tools
projects:lps:index
Differences
Link to this comparison view
Next revision
Previous revision
projects:lps:index [2016-05-25 16:02]
projects:lps:index [2020-05-12 14:30]
Line 1: Line 1:
-====== Loco Positioning System ====== +<WRAP center round important 60%
- +This page has deprecated and moved to the new documentation framework of the main Bitcraze website. Please go to [[https://www.bitcraze.io/documentation/system/]]
-<WRAP center round info+
-//**Early access**// +
-Currently this product line is in [[https://www.bitcraze.io/early-access/|early access]]. Basically we have finalized and tested the hardware but the software it still considered //beta//.+
 </WRAP> </WRAP>
 +====== Loco Positioning System ======
 The loco positioning system (LPS) project is a set of hardware and software designed to implement a local positioning system (LPS). The hardware is based on the Decawave DW1000 chip. For more information about the system see the [[doc:lps:index|Loco positioning system documentation]] The loco positioning system (LPS) project is a set of hardware and software designed to implement a local positioning system (LPS). The hardware is based on the Decawave DW1000 chip. For more information about the system see the [[doc:lps:index|Loco positioning system documentation]]
 ===== Hardware description ===== ===== Hardware description =====
-The hardware consists two parts, nodes and decks.+The hardware consists multiple parts:
   * [[projects:lps:node|Loco positioning node]]: Mainly aimed as an anchor but can be used as a tag or UWB radio transceiver and sniffer.   * [[projects:lps:node|Loco positioning node]]: Mainly aimed as an anchor but can be used as a tag or UWB radio transceiver and sniffer.
-  * [[projects:lps:deck|Loco positioning deck]]: USB radio deck to be installed on Crazyflie 2.0+  * [[projects:lps:deck|Loco positioning deck]]: USB radio deck to be installed on Crazyflie 2.
 +  * [[projects:lps:roadrunner|Roadrunner]]: Standalone tag aimed at enabling other robots to use the positioning
projects/lps/index.txt · Last modified: 2020-05-12 14:30 by kimberly
