projects:lps:index [2016-02-08 15:01] arnaud [LPS Node] |
projects:lps:index [2020-05-12 14:30] (current) kimberly |
- | <WRAP center round info> | + | <WRAP center round important 60%> |
- | //**Alpha production**// | + | This page has deprecated and moved to the new documentation framework of the main Bitcraze website. Please go to [[https:// |
- | Currently this product is only available as part if our [[https:// | + | |
- | ====== System | + | ====== |
- | The local positioning system is based on the [[http:// | + | |
- | <WRAP group> | + | The loco positioning system |
- | <WRAP half column> | + | |
- | Our testsystem uses the following components: | + | |
- | * 6 anchors | + | |
- | * 1 deck | + | |
- | * Computer running [[http:// | + | |
- | * Crazyflie client with ZMQ to mix manual and automatic control | + | |
- | Here' | + | |
- | {{youtube> | + | |
- | ====== Hardware description ====== | + | |
- | The hardware | + | |
- | ===== LPS Node ===== | + | |
- | <WRAP group> | + | |
- | Connects and buttons: | + | |
- | - **uUSB**: Used to power board (and will have command-line interface) | + | |
- | - **DC-jack**: | + | |
- | - **Terminal**: | + | |
- | - **Reset**: Reset the board | + | |
- | - **Exp connector**: | + | |
- | - **USR & DFU**: If pressed and held during reset or power on this will put the board into DFU bootloader mode. When the system is up and running the button is still unused, but could be used to trigger functionality in the firmware. | + | |
- | - **SWD**: Connector for programming and debugging MCU. Uses same pin-out as Crazyflie 2.0 and [[http:// | + | |
- | - **FTDI**: Connector | + | |
- | - **M3 mounting holes** | + | |
- | MCU controlled LEDs: | + | |
- | * **POWER**: On when board is powered | + | |
- | * **RANGING**: | + | |
- | * **SYNC**: TDB | + | |
- | * **MODE**: On in Anchor mode, off in Tag mode and blinking in Sniffer mode | + | |
- | DWM1000 controlled LEDs: | + | |
- | * **TX**: Transmitting | + | |
- | * **RX**: Receiving | + | |
- | * **SFD**: Received packet timestamp | + | |
- | * **RXOK**: Packet received without error | + | |
- | ===== DWM deck ===== | + | |
- | TBD | + | |
- | ====== Firmware ====== | + | |
- | ===== DWM Node ===== | + | |
- | ==== Building and flashing ==== | + | |
- | Building and flashing is described in the [[https:// | + | |
- | Flashing via DFU requires [[http:// | + | |
- | The firmware for the DWM deck is included in the Crazyflie 2.0 firmware build (recent) and activated when the deck is attached. The deck contains a small memory that holds the address of the board as well as the addresses of the anchors it will use for ranging. | + | |
- | More information | + | |
- | ====== ROS ====== | + | ===== Hardware description |
+ | The hardware consists multiple parts: | ||
+ | * [[projects: | ||
