projects:lps:index [2016-03-21 15:22] kristoffer [Building and flashing] |
projects:lps:index [2020-05-12 14:30] (current) kimberly |
| - | <WRAP center round info> | + | <WRAP center round important 60%> |
| - | //**Alpha production**// | + | This page has deprecated and moved to the new documentation framework of the main Bitcraze website. Please go to [[https:// |
| - | Currently this product is only available as part if our [[https:// | + | |
| - | ====== System | + | ====== |
| - | The local positioning system is based on the [[http:// | + | |
| - | <WRAP group> | + | The loco positioning system |
| - | <WRAP half column> | + | |
| - | Our testsystem uses the following components: | + | |
| - | * 6 anchors | + | |
| - | * 1 deck | + | |
| - | * Computer running [[http:// | + | |
| - | * Crazyflie client with ZMQ to mix manual and automatic control | + | |
| - | Here' | + | |
| - | {{youtube> | + | |
| - | ====== Hardware description ====== | + | |
| - | The hardware | + | |
| - | ===== LPS Node ===== | + | |
| - | <WRAP group> | + | |
| - | Connects and buttons: | + | |
| - | - **uUSB**: Used to power board (and will have command-line interface) | + | |
| - | - **DC-jack**: | + | |
| - | - **Terminal**: | + | |
| - | - **Reset**: Reset the board | + | |
| - | - **Exp connector**: | + | |
| - | - **USR & DFU**: If pressed and held during reset or power on this will put the board into DFU bootloader mode. When the system | + | |
| - | - **SWD**: Connector for programming and debugging MCU. Uses same pin-out as Crazyflie 2.0 and [[http:// | + | |
| - | - **FTDI**: Connector designed for the FTDI serial-to-USB cable (TTL-232R-3V3). Except for getting a serial console for debugging it can also be used to power the board. Note that signals are 3V3 and power is 5V. | + | |
| - | - **M3 mounting holes** | + | |
| - | MCU controlled LEDs: | + | |
| - | * **POWER**: On when board is powered | + | |
| - | * **RANGING**: | + | |
| - | * **SYNC**: TDB | + | |
| - | * **MODE**: On in Anchor mode, off in Tag mode and blinking in Sniffer mode | + | |
| - | DWM1000 controlled LEDs: | + | |
| - | * **TX**: Transmitting | + | |
| - | * **RX**: Receiving | + | |
| - | * **SFD**: Received packet timestamp | + | |
| - | * **RXOK**: Packet received without error | + | |
| - | ===== DWM deck ===== | + | |
| - | The DWM deck is designed to be installed | + | |
| - | The deck contains a row of 4 LEDs, all controlled by the DWM1000: | + | |
| - | ====== Firmware ====== | + | |
| - | ===== DWM Node ===== | + | |
| - | ==== Building and flashing ==== | + | |
| - | Building and flashing is described in the [[https:// | + | |
| - | Flashing via DFU requires [[http:// | + | |
| - | To flash the firmware use | + | |
| - | The firmware for the DWM deck is included in the Crazyflie 2.0 firmware build (recent) and activated when the deck is attached. The deck contains a small memory that holds the address of the board as well as the addresses of the anchors it will use for ranging. | + | |
| - | More information on building the firmware and the firmware itself can be found [[https:// | + | |
| - | ====== ROS ====== | + | |
| - | The ROS module for positioning | + | |
| - | To get started from a newly installed ubuntu: | + | |
| - | - Install ROS: http:// | + | |
| - | - Create your workspace: http:// | + | |
| - | - Clone https:// | + | |
| - | - Run // | + | |
| - | - Source the workspace // | + | |
| - | - Run //rosdep install bitcraze_lps_estimator// | + | |
| - | The position of the anchor has to be entered in a configuration file. The file should be // | + | |
| - | <file yaml anchor_pos.yaml> | + | |
| - | n_anchors: 6 | + | |
| - | anchor0_pos: | + | |
| - | anchor1_pos: | + | |
| - | anchor2_pos: | + | |
| - | anchor3_pos: | + | |
| - | anchor4_pos: | + | |
| - | anchor5_pos: | + | |
| - | The positions are in meter, [x, y, z], from the origin. | + | |
| - | When this file is configured, the // | + | |
| - | <code bash> | + | |
| - | $ roslaunch bitcraze_lps_estimator dwm_loc.launch uri: | + | |
| - | ====== Set up ====== | + | |
| - | the dwm nodes can be configured in 3 different modes; tag, anchor or sniffer. By default they come pre-configured as anchors. The anchors are powered with 5v either through micro usb, power jack or screw terminal | + | |
| - | A nice way to power the anchors is to use usb power pack like we do here: | + | |
| - | {{: | + | ===== Hardware description ===== |
| + | The hardware consists multiple parts: | ||
| + | * [[projects: | ||
| - | Place the anchors at least 15 cm from the floor/ | ||
| - | We use 3d printed anchor-stands that can be found at: https:// | ||
| - | One of the main consideration for the anchor placement is the [[https:// | ||
