Both sides previous revision Previous revision | |||
projects:lps:roardrunner [2019-01-29 16:57] macke removed |
— (current) | ||
- | ====== Roadrunner ====== | ||
- | The Roadrunner is an advanced LPS tag based off the Crazyflie 2.1 hardware and runs the same firmware base as the Crazyflie 2.X. | ||
- | <WRAP group> | ||
- | <WRAP half column> | ||
- | Connects and buttons: | ||
- | - **Power/ | ||
- | - **Deck port**: Crazyflie 2.X expansion deck connector ([[projects: | ||
- | - **SWD**: Debug port (not mounted) | ||
- | - **ON/ | ||
- | - **UF.L**: 2.4Ghz antenna connector (for nRF) | ||
- | - **nRF LEDs**: nRF controlled LEDs | ||
- | - **STM32 LEDs**: STM32 controlled LEDs | ||
- | - **DWM1000 LEDs**: DWM1000 controlled LEDs | ||
- | - **uSB power and data**: Full-speed USB interface | ||
- | - **M3 mounting holes**: The mounting holes used in the enclosure | ||
- | - **Power**: Extra 2.54mm spaced power connector (not mounted) | ||
- | - **USART**: Extra 2.54mm spaced UART connector (not mounted) | ||
- | nRF controlled LEDs: | ||
- | * **D7**: | ||
- | * **D8**: | ||
- | STM controlled LEDs: | ||
- | * **D1**: | ||
- | * **D2**: | ||
- | * **D11**: | ||
- | * **D12**: | ||
- | DWM1000 controlled LEDs: | ||
- | * **TX**: Transmitting | ||
- | * **RX**: Receiving | ||
- | * **SFD**: Received packet timestamp | ||
- | * **RXOK**: Packet received without error | ||
- | ===== Schematic ===== | ||
- | Schematics of Roadrunner RevB {{: | ||
