projects:virtualmachine:index [2013-05-01 20:13] macke created |
projects:virtualmachine:index [2021-06-24 16:16] (current) kimberly |
| ====== Bitcraze Virtual Machine ====== | ====== Bitcraze Virtual Machine ====== | ||
| - | In order to easily get going with the development of Bitcraze projects we have pre-configured a virtual machine that can be imported into [[http://www.vmware.com/ | + | In order to easily get going with the development of Bitcraze projects we have pre-configured a virtual machine that can be imported into [[https://www.virtualbox.org/|Oracle VirtualBox]]. It contains pre-requisites needed for development and usage of the projects at Bitcraze. For more information on what's included in the Bitcraze VM have a look at [[https://github.com/bitcraze/ |
| - | The username/password for the virtual machine | + | <WRAP center round info> |
| + | The virtual machine | ||
| - | If you have any comments or suggestions drop by the [[http://forum.bitcraze.se/viewtopic.php? | + | The VM is built using Packer, so if you would like to build you're own just clone the [[https://github.com/bitcraze/bitcraze-vm|Bitcraze VM repo]] and follow the instructions in the README. For reference |
| - | ====== Download ====== | + | |
| - | Currently the virtual machine applicance is only available via torrent using [[http:// | + | |
| - | ====== | + | For information on how to install the VM please have a look at our [[https:// |
| - | The machine includes: | + | |
| - | * Pre-cloned | + | ====== |
| - | * All development tools to compile Crazyflie firmware and bootloader, Crazyradio firmware | + | To download the latest |
| - | * All python lib to run the Crazyflie PC client | + | |
| - | * Eclipse pre-configured to develop on Crazyflie firmware and PC-Client + QtDesigner to edit the GUI files | + | |
| - | * A readme that explains how to start | + | |
| - | The next version | + | ==== Previous |
| - | * Hardware dev tools | + | * Bitcraze VM 2017.03 ([[http:// |
| - | * Tool and configuration to debug the Crazyflie | + | * Bitcraze VM 2016-06 |
| - | * Reduce the image size (it is currently 2.2GB which I find quite big, I should be able to cut a lot of useless stuff by starting from a minimal install) | + | * Bitcraze |
| - | * More documentation in the VM and on the Wiki | + | |
| - | Pulling the latest changes of the firmware | + | [[projects: |
| - | cd ~/ | + | |
| - | hg pull && hg update | + | |
| - | cd ~/ | + | |
| - | ====== How do I build the firmware with the latest changes from the repository on Bitbucket? ====== | ||
| - | Running the following commands will pull the latest changes from the repository on Bitbucket and build the firmware. For updating the Crazyflie use the resulting // | ||
| - | cd ~/ | ||
| - | hg pull && hg update | ||
| - | make CLOAD=1 DEBUG=0 | ||
