projects:virtualmachine:index [2013-05-23 14:15] macke |
projects:virtualmachine:index [2021-06-24 16:16] (current) kimberly |
| ====== Bitcraze Virtual Machine ====== | ====== Bitcraze Virtual Machine ====== | ||
| - | In order to easily get going with the development of Bitcraze projects we have pre-configured a virtual machine that can be imported into [[http://www.vmware.com/ | + | In order to easily get going with the development of Bitcraze projects we have pre-configured a virtual machine that can be imported into [[https://www.virtualbox.org/|Oracle VirtualBox]]. It contains pre-requisites needed for development and usage of the projects at Bitcraze. For more information on what's included in the Bitcraze VM have a look at [[https://github.com/bitcraze/ |
| - | The username/password for the virtual machine | + | <WRAP center round info> |
| + | The virtual machine | ||
| - | If you have any comments or suggestions drop by the [[http://forum.bitcraze.se/viewtopic.php? | + | The VM is built using Packer, so if you would like to build you're own just clone the [[https://github.com/bitcraze/bitcraze-vm|Bitcraze VM repo]] and follow the instructions in the README. For reference |
| - | ====== Download ====== | + | |
| - | Currently the virtual machine applicance is only available via torrent using [[http:// | + | |
| - | ====== What's in the virtual machine? ====== | + | For information on how to install |
| - | The machine includes: | + | |
| - | * Pre-cloned version of the public bicraze projects from bitbucket (software | + | |
| - | * All development tools to compile Crazyflie firmware | + | |
| - | * All python lib to run the Crazyflie | + | |
| - | * Eclipse pre-configured to develop on Crazyflie firmware and PC-Client + QtDesigner to edit the GUI files | + | |
| - | * A readme that explains how to start | + | |
| - | The next version will also include: | + | ====== Download ====== |
| - | * Hardware dev tools | + | To download |
| - | * Tool and configuration to debug the Crazyflie (currently only tools to compile are present) | + | |
| - | * Reduce | + | |
| - | * More documentation in the VM and on the Wiki | + | |
| - | ====== How do I pull the latest stable release from the repository on Bitbucket? ====== | + | ==== Previous version |
| - | Pulling the latest stable release of the firmware and client can be done using the following commands: | + | * Bitcraze VM 2017.03 ([[http://files.bitcraze.se/ |
| - | < | + | * Bitcraze VM 2016-06 ([[http:// |
| - | cd ~/projects/crazyflie-firmware | + | * Bitcraze VM 0.8 ([[http:// |
| - | hg pull && hg update | + | |
| - | cd ~/projects/crazyflie-pc-client | + | |
| - | </code> | + | |
| - | Pulling the latest changes of the firmware | + | [[projects: |
| - | cd ~/ | + | |
| - | cd ~/ | + | |
| - | ====== How do I build the firmware? ====== | ||
| - | Running the following commands will build the firmware which can be flashed with the wireless bootloader. For updating the Crazyflie use the resulting // | ||
| - | cd ~/ | ||
| - | make CLOAD=1 DEBUG=0 | ||
