projects:virtualmachine:index [2013-06-10 11:27] macke |
projects:virtualmachine:index [2021-06-24 16:16] (current) kimberly |
| - | ====== Bitcraze Virtual Machine ====== | + | <WRAP center round important 60%> |
| - | In order to easily get going with the development | + | This page has deprecated and moved to the new documentation framework |
| - | If you would like to create your own virtual machine instead of downloading ours, then have a look at [[projects: | ||
| - | You can download | + | In order to easily get going with the development |
| - | * Bitcraze | + | |
| - | * Bitcraze VM 0.3 from Mega | + | |
| - | ====== VM info ====== | + | <WRAP center round info> |
| - | The latest available version of the VM is 0.3. | + | // |
| - | < | + | The virtual machine can also be imported into [[http:// |
| - | OS | + | </WRAP> |
| - | HDD : 10 GB (dynamically sized) | + | |
| - | RAM : 1 GB | + | |
| - | User: bitcraze | + | |
| - | Pass: crazyflie | + | |
| - | </code> | + | |
| - | ===== Configuration ===== | + | The VM is built using Packer, so if you would like to build you're own just clone the [[https:// |
| - | The VM comes pre-configured with the following: | + | |
| - | * udev rules for Crazyradio and bootloader | + | |
| - | * Pre-configured USB filters for passing Crazyradio/NRF BOOT to the VM (not enabled by default) | + | |
| - | ===== Installed software ===== | + | For information on how to install |
| - | Below is a overview of what's installed in the virtual machine: | + | |
| - | * VirtualBox guest additions (for network sharing, screen resize, etc) | + | |
| - | * gnu-arm-none-eabi toolchain | + | |
| - | * Mercurial | + | |
| - | * TortoiseHG | + | |
| - | * pyusb, pygame | + | |
| - | * Qt4 and QtDesigner | + | |
| - | * KiCad | + | |
| - | * Eclipse with compiling/debugging/flashing configured (for use with BusBlaster) | + | |
| - | * gedit | + | |
| - | * SDCC 3.2 | + | |
| - | ===== Projects | + | ====== |
| - | The following projects are cloned into the VM: | + | To download |
| - | * crazyflie-firmware | + | |
| - | * crazyflie-bootloader | + | |
| - | * crazyflie-pc-client | + | |
| - | * crazyradio-firmware | + | |
| - | * crazyradio-electronics | + | |
| - | There are also short-cuts on the desktop to easily run the Crazyflie PC client and also to update all the projects to the latest version available on Bitbucket. | + | |
| - | ===== Development | + | |
| - | The VM comes pre-installed and pre-configured for development. Here's what you can do: | + | |
| - | * Update and build the latest | + | |
| - | * Debug the Crazyflie firmware via JTAG (pre-configured for BusBlaster) | + | |
| - | * View and modify the Crazyradio electronics design | + | |
| - | * Develop for Crazyflie PC client with QtDesigner for the UI | + | |
| - | ===== HOW-TOs ===== | + | |
| - | ==== Update all the projects ==== | + | |
| - | If you would like to update to the latest version from Bitbucket for all the projects you can either use the short-cut on the desktop (//Update all projects//) or run the following command: | + | |
| - | /home/bitcraze/ | + | |
| - | </code> | + | |
| - | ==== Run the Crazyflie PC client ==== | + | |
| - | If you would like to fly the Crazyflie then you should to the following: | + | |
| - | * Insert the controller and Crazyradio and pass them to the VM. In VirtualBox this is done by right-clicking on the USB icon in the bottom left hand of the screen and selecting the Crazyradio and the controller | + | |
| - | * Start the cfclient either by using the short-cut on the desktop (// | + | |
| - | * Press the //Connect// button and select the URI starting with //radio// and then press //Connect// | + | |
| - | **PLEASE NOTE:** If no controller is passed to VirtualBox the default controller will be the //VirtualBox USB Tablet//. This device together with the default controller mapping will set the thrust depending on where the mouse-pointer is on the screen. Make sure to check that there' | + | ==== Previous version ==== |
| - | ==== How do I pull the latest stable release from the repository on Bitbucket? | + | ====== Tutorials ====== |
| - | Pulling the latest stable release of the firmware | + | [[projects: |
| - | cd ~/ | + | |
| - | hg pull && hg update -C 2013.4 | + | |
| - | cd ~/ | + | |
| - | hg pull && hg update -C 2013.4.2 | + | |
| - | ==== Build the Crazyflie firmware ==== | ||
| - | Running the following commands will build the firmware which can be flashed with the wireless bootloader. For updating the Crazyflie use the resulting // | ||
| - | cd ~/ | ||
| - | make CLOAD=1 DEBUG=0 | ||
