projects:virtualmachine:index [2014-03-10 18:09] macke |
projects:virtualmachine:index [2021-06-24 16:16] (current) kimberly |
| - | ====== Bitcraze Virtual Machine ====== | + | <WRAP center round important 60%> |
| - | In order to easily get going with the development | + | This page has deprecated and moved to the new documentation framework |
| - | If you would like to create your own virtual machine instead of downloading ours, then have a look at [[projects: | ||
| - | **Please note:** All the instructions here (and on sub-pages) are always updated to match the latest available version of the VM and might not be valid for earlier versions. | + | ====== Bitcraze Virtual Machine ====== |
| + | In order to easily get going with the development of Bitcraze projects we have pre-configured a virtual machine that can be imported into [[https:// | ||
| - | ====== Download ====== | + | <WRAP center round info> |
| - | You can download the VM using one of the link below: | + | //**Note**// |
| - | * Bitcraze VM 0.5 ([[http://files.bitcraze.se/dl/Bitcraze_VM_0.5.ova.torrent|torrent]]) ([[http:// | + | The virtual machine can also be imported into [[http://www.vmware.com/products/player/|WM Player]] however you will then have to install the [[https://www.vmware.com/support/ws5/doc/ws_newguest_tools_linux.html# |
| - | * Bitcraze VM 0.4 ([[http://tracker.bitcraze.se/torrents/Bitcraze%20VM%200.4.ova.torrent|torrent]]) ([[http:// | + | </WRAP> |
| - | * Bitcraze VM 0.3 ([[http://taffanel.org/tracker/ | + | |
| - | * Bitcraze VM 0.2 ([[http:// | + | |
| - | Please note that direct downloads are hosted at MEGA, so it's limited | + | The VM is built using Packer, so if you would like to build you're own just clone the [[https:// |
| - | The latest available version of the VM is 0.5. | + | |
| - | OS | + | |
| - | HDD : ~8.8 GB (dynamically sized) | + | |
| - | RAM : 1 GB | + | |
| - | User: bitcraze | + | |
| - | Pass: crazyflie | + | |
| - | ===== Configuration ===== | + | For information on how to install the VM please have a look at our [[https:// |
| - | The VM comes pre-configured | + | |
| - | * udev rules for Crazyradio and bootloader | + | |
| - | * Pre-configured USB filters for passing Crazyradio/NRF BOOT to the VM (not enabled by default) | + | |
| - | **NOTE**: The USB filters in the 0.3 version of the VM specify a serial number for the radio dongle. | + | ====== |
| - | + | To download | |
| - | ===== Installed software | + | |
| - | Below is a overview of what's installed in the virtual machine: | + | |
| - | * VirtualBox guest additions (for network sharing, screen resize, etc) | + | |
| - | * gnu-arm-none-eabi toolchain and build tools | + | |
| - | * Mercurial | + | |
| - | * TortoiseHG/ | + | |
| - | * pyusb, pygame and pyqt | + | |
| - | * Qt4 and QtDesigner | + | |
| - | * PyQtGraph | + | |
| - | * PyCharm | + | |
| - | * Oracle Java JRE (for PyCharm) | + | |
| - | * KDE Marble built with Python-bindings | + | |
| - | * KiCad (built from source) | + | |
| - | * Eclipse with compiling/ | + | |
| - | * gedit | + | |
| - | * SDCC 3.2 | + | |
| - | ===== Projects | + | |
| - | The following projects are cloned into the VM: | + | |
| - | * crazyflie-firmware | + | |
| - | * crazyflie-bootloader | + | |
| - | * crazyflie-pc-client | + | |
| - | * crazyradio-firmware | + | |
| - | * crazyradio-electronics | + | |
| - | There are also short-cuts on the desktop to easily run the Crazyflie PC client and also to update all the projects to the latest version | + | |
| - | ===== Development ===== | + | |
| - | The VM comes pre-installed and pre-configured for development. Here's what you can do: | + | |
| - | * Update and build the latest versions | + | |
| - | * Easily flash the Crazyflie firmware from Eclipse using the radio | + | |
| - | * [[projects:virtualmachine: | + | |
| - | * View and modify the Crazyradio electronics design | + | |
| - | * Develop for Crazyflie PC client with QtDesigner for the UI | + | |
| - | ===== HOW-TOs ===== | + | |
| - | ==== Update all the projects ==== | + | |
| - | If you would like to update to the latest version from Bitbucket for all the projects you can either use the short-cut on the desktop (//Update all projects//) or run the following command: | + | |
| - | /home/bitcraze/bin/update_all_projects.sh | + | |
| - | ==== Run the Crazyflie PC client ==== | + | |
| - | If you would like to fly the Crazyflie then you should to the following: | + | |
| - | * Insert the controller and Crazyradio and pass them to the VM. In VirtualBox this is done by right-clicking on the USB icon in the bottom left hand of the screen and selecting the Crazyradio and the controller | + | |
| - | * Start the cfclient either by using the short-cut on the desktop (// | + | |
| - | * Press the //Connect// button and select the URI starting with //radio// and then press //Connect// | + | |
| - | **PLEASE NOTE:** If no controller is passed to VirtualBox the default controller will be the //VirtualBox USB Tablet//. This device together with the default controller mapping will set the thrust depending on where the mouse-pointer is on the screen. Make sure to check that there' | + | ==== Previous version ==== |
| - | ==== How do I pull the latest stable release from the repository on Bitbucket? | + | ====== Tutorials ====== |
| - | Pulling the latest stable release of the firmware | + | [[projects: |
| - | cd ~/ | + | |
| - | hg pull && hg update -C 2013.4 | + | |
| - | cd ~/ | + | |
| - | hg pull && hg update -C 2013.4.2 | + | |
| - | ==== Build the Crazyflie firmware ==== | ||
| - | Running the following commands will build the firmware which can be flashed with the wireless bootloader. For updating the Crazyflie use the resulting // | ||
| - | cd ~/ | ||
| - | make CLOAD=1 DEBUG=0 | ||
