projects:virtualmachine:jtag_debug [2016-10-10 11:36] tobias |
projects:virtualmachine:jtag_debug [2021-06-02 11:21] (current) kimberly |
| + | [[https:// | ||
| ====== Prerequisites ====== | ====== Prerequisites ====== | ||
| Line 5: | Line 11: | ||
| ======= Crazyflie 2.0 ======= | ======= Crazyflie 2.0 ======= | ||
| - | The debug adapter is needed (or a cable could be made) to convert the ARM 20pin JTAG connector to the 6pin JST connector used on the Crazyflie 2.0. You will also need a JTAG/SWD debugger. The virtual machine is pre-configured to use the STLink v2 but can be set-up with any JTAG/SWD device that openOCD supports. | + | The [[projects: |
| The STM32F405 debug connector is located under the micro USB connector. | The STM32F405 debug connector is located under the micro USB connector. | ||
