projects:virtualmachine:tutorials:vmware-win7 [2015-07-15 16:31] 127.0.0.1 external edit |
projects:virtualmachine:tutorials:vmware-win7 [2016-07-12 09:19] (current) arnaud |
| ====== How to setup and install the VM in VMware, Windows 7 & First steps to learn to program the CF2 ====== | ====== How to setup and install the VM in VMware, Windows 7 & First steps to learn to program the CF2 ====== | ||
| + | This tutorial is covering a previous version of the virtual machine and the development part might be outdated. Once you have the VM up and running you can look at the [[https:// | ||
| __**Noob Guide – Windows 7. | __**Noob Guide – Windows 7. | ||
| Install the VM, set it up (to your preferences) and get started with programming the Crazyflie 2.0 (by the end of this guide, you will have flashed a custom firmware into your Crazyflie 2.0!!). | Install the VM, set it up (to your preferences) and get started with programming the Crazyflie 2.0 (by the end of this guide, you will have flashed a custom firmware into your Crazyflie 2.0!!). | ||
