doc:crazyflie:bootloader:protocol [2015-07-31 14:43] arnaud [LOAD_BUFFER] |
doc:crazyflie:bootloader:protocol [2017-02-01 18:50] whoenig [Commands summary] |
Line 79: | Line 79: | ||
| 0x19 | FLASH_STATUS | | 0x19 | FLASH_STATUS | ||
| 0x1C | READ_FLASH | | 0x1C | READ_FLASH | ||
+ | | 0xFF | RESET_INIT | ||
+ | | 0xF0 | RESET | Only implemented in version 0x10 target 0xFE | | ||
+ | | 0x01 | ALLOFF | Only implemented in version 0x10 target 0xFE | | ||
+ | | 0x02 | SYSOFF | Only implemented in version 0x10 target 0xFE | | ||
+ | | 0x03 | SYSON | Only implemented in version 0x10 target 0xFE | | ||
+ | | 0x04 | GETVBAT | Only implemented in version 0x10 target 0xFE | | ||
==== GET_INFO ==== | ==== GET_INFO ==== | ||
Line 153: | Line 159: | ||
| 1-2 | page | Buffer page to load into | | | 1-2 | page | Buffer page to load into | | ||
| 3-4 | Address | Address in the buffer page to load from | | | 3-4 | Address | Address in the buffer page to load from | | ||
- | | 5-28 | data | Data to load | | + | | 5-31 | data | Data to load | |
Line 167: | Line 173: | ||
| 0 | READ_BUFFER | | 0 | READ_BUFFER | ||
| 1-2 | page | Buffer page to read | | | 1-2 | page | Buffer page to read | | ||
- | | | + | | 3-4 | Address | Address in the buffer page to read from | |
Line 174: | Line 180: | ||
| 1-2 | page | Buffer page read | | | 1-2 | page | Buffer page read | | ||
- | | | + | | 3-4 | Address | Address in the buffer page read from | |
Line 231: | Line 237: | ||
| 0 | READ_FLASH | | 0 | READ_FLASH | ||
| 1-2 | page | Flash page to read | | | 1-2 | page | Flash page to read | | ||
- | | | + | | 3-4 | Address | Address in the flash page to read from | |
Line 238: | Line 244: | ||
| 1-2 | page | Flash page read | | | 1-2 | page | Flash page read | | ||
- | | | + | | 3-4 | Address | Address in the flash page read from | |
