doc:crazyradio:install_windows_zadig [2014-01-30 10:46] arnaud |
doc:crazyradio:install_windows_zadig [2021-06-24 16:54] (current) kimberly |
| ====== Crazyradio manual windows installation using zadig ====== | ====== Crazyradio manual windows installation using zadig ====== | ||
| Line 7: | Line 10: | ||
| First of all download Zadig from its website: http:// | First of all download Zadig from its website: http:// | ||
| - | Plug Crazyradio in the PC. Windows should display some installation window. On windows8 it does nothing and closes itself. On windows 7 you have to close the install failed window. | + | Plug Crazyradio in the PC. Windows should display some installation window. On windows8 it does nothing and closes itself. On windows 7 you have to close the install failed window. On Windows XP just click " |
| Once windows is out of the way, launch Zadig, you should see the Crazyradio in the list. Select crazyradio, select libusb and click install: | Once windows is out of the way, launch Zadig, you should see the Crazyradio in the list. Select crazyradio, select libusb and click install: | ||
| Line 26: | Line 29: | ||
| + | ===== Troubleshooting ===== | ||
| + | If things does not work check that the Crazyradio appears as a libusb device in the Windows device manager. If it is not the case try to reinstall the driver as described above. | ||
| + | If you are having problems with the radio not working all the time (like scanning but not connecting) you can try to install the libUSBK driver, it have been behaving a bit better to some version of pyusb: | ||
