doc:lps:index [2017-05-11 14:31] bjorn |
doc:lps:index [2018-10-31 18:03] kristoffer |
- | <WRAP center round info> | + | ====== Loco positioning system ====== |
- | **IMPORTANT** | + | |
- | We're currently working on updating the documentation for the Loco positioning system. | + | The Loco Positioning system (LPS) project is a set of hardware and software designed to implement a local positioning system. |
- | </WRAP> | + | * [[projects:lps:index|Hardware documentation]] |
+ | * [[https:// | ||
- | The Loco Positioning system (LPS) project is a set of hardware | + | To make the documentation easier to grasp there' |
+ | * **Deck | ||
+ | * **Tag and anchor:** These refer to roles when ranging (i.g depending | ||
- | ===== System overview ===== | + | ====== System overview |
- | * ToA ([[doc: | + | |
- | * [[doc: | + | |
+ | * [[doc: | ||
+ | * [[doc: | ||
+ | * [[doc: | ||
+ | * [[doc: | ||
+ | * [[doc: | ||
+ | ===== Protocols ===== | ||
+ | * [[doc: | ||
+ | * [[doc: | ||
+ | * [[doc: | ||
- | This getting started documentation is intended to guide you from receiving your Loco Positioning Indoor Explorer Bundle to having an autonomous Crazyflie 2.0. | ||
- | ==== Tools ==== | + | ===== Tools ===== |
- | * [[doc: | + | * [[doc: |
* [[doc: | * [[doc: | ||
- | + | * [[https:// | |
- | ==== Prerequisites ==== | + | |
- | In order to illustrate | + | |
- | The Kalman filter used position Crazyflie in the LPS is not yet part of the default firmware so you need to compile the Crazyflie firmware with Kalman support activated. Clone or pull the latest version from [[https:// | + | |
- | make clean | + | |
- | make | + | |
- | make cload | + | |
- | Use the [[doc: | + | |
- | Use the LPS tab of the Crazyflie client to store the physical anchor positions in the anchors. The communication from the client to the anchors is bridged through a Crazyflie, so you must have a Crazyflie with an Loco Positioning deck connected to the client. | + | |
- | The [[doc: | + | |
