User Tools
Site Tools
doc:lps:tdoa3:protocol
Differences
Link to this comparison view
Next revision
Previous revision
doc:lps:tdoa3:protocol [2018-05-02 14:38]
doc:lps:tdoa3:protocol [2018-11-06 10:10]
Line 1: Line 1:
-====== TDoA Anchor protocol V3 (experimental) ======+====== TDoA Anchor protocol V3 ======
-<WRAP center round tip 80%> +===== Design goals =====
-**NOTE**+
-This is work in progress. The specifications on this page may change at any time without backwards compatibility.  +The protocol is designed to be used with a large number of anchors covering a big area. Each anchor has a limited reach and covers only a small area, but by adding more anchors the system can cover an (virtually) unlimited area. At any point in the covered area, 5-10 anchors should be within range of a Tag.
-</WRAP> +
-This page describes the [[doc:lps:tdoa3|TDoA]] anchor protocol V3. +
-===== System architecture ===== +
-The protocol is designed to be used with a large number of anchors covering a big area. Each anchor has a limited reach and covers only a small area, but by adding more anchors the system will be able to cover an (virtually) unlimited area. At any point in the covered area, 5-10 anchors should be within range of a Tag. +
 Each anchor knows its own position in a global coordinate system and broadcasts this information in time stamped packets that are used by one or more Tags to estimate their position. Each anchor knows its own position in a global coordinate system and broadcasts this information in time stamped packets that are used by one or more Tags to estimate their position.
Line 20: Line 11:
 ===== Packet scheduling ===== ===== Packet scheduling =====
-Packets are transmitted at random times and collisions are handled by the system.+Packets are transmitted at random times and collisions are handled by the receiving party.
 ===== Packet format ===== ===== Packet format =====
-There is only one packet format.
 <ditaa> <ditaa>
-Packet    :   | Header | Remote anchor data | +Packet    :         | Header | Remote anchor data | LPP data |
                                   7 bytes                                   7 bytes
-                8 bits   8 bits     32 bits       8 bits +                      8 bits   8 bits     32 bits       8 bits
-Header    :   |  type  |  seq   | txTimeStamp | remoteCount | +Header    :         |  type  |  seq   | txTimeStamp | remoteCount |
Line 46: Line 35:
 Remote anchor data: |   id   | hasDistance |  seq   | rxTimeStamp |   distance   | Remote anchor data: |   id   | hasDistance |  seq   | rxTimeStamp |   distance   |
 </ditaa> </ditaa>
Line 60: Line 49:
     * **rxTimeStamp:** receive time stamp of latest packet from the remote anchor     * **rxTimeStamp:** receive time stamp of latest packet from the remote anchor
     * **distance:** time of flight between the current anchor and the remote anchor in radio timer ticks     * **distance:** time of flight between the current anchor and the remote anchor in radio timer ticks
 +  * **LPP data:** See [[doc:lps:lpp#lpp_short_packets|LPP short packet description]]
 ===== Tag implementation ===== ===== Tag implementation =====
-A TDoA tag is simply an UWB sniffer. A sniffer can use the data in the packets together with the packet receive timestamps to calculate its position.+A TDoA tag is simply an UWB sniffer. A sniffer can use the data in the packets together with the timestamps when packets are received to calculate its position.
 +===== Calculating TDoA =====
 +[[doc:lps:tdoa:principles|Please see TDoA positioning principles]]
doc/lps/tdoa3/protocol.txt · Last modified: 2020-05-12 14:08 by kimberly
