doc:lps:tdoa3:protocol [2018-10-31 18:10] kristoffer |
doc:lps:tdoa3:protocol [2019-09-05 14:45] kimberly |
- | ====== TDoA Anchor protocol V3 (experimental) ====== | ||
- | ===== System architecture | + | <WRAP center round important 60%> |
+ | https:// | ||
+ | ====== TDoA Anchor protocol V3 ====== | ||
+ | ===== Design goals ===== | ||
The protocol is designed to be used with a large number of anchors covering a big area. Each anchor has a limited reach and covers only a small area, but by adding more anchors the system can cover an (virtually) unlimited area. At any point in the covered area, 5-10 anchors should be within range of a Tag. | The protocol is designed to be used with a large number of anchors covering a big area. Each anchor has a limited reach and covers only a small area, but by adding more anchors the system can cover an (virtually) unlimited area. At any point in the covered area, 5-10 anchors should be within range of a Tag. | ||
Line 11: | Line 21: | ||
===== Packet scheduling ===== | ===== Packet scheduling ===== | ||
- | Packets are transmitted at random times and collisions are handled by the system. | + | Packets are transmitted at random times and collisions are handled by the receiving party. |
===== Packet format ===== | ===== Packet format ===== | ||
- | There is only one packet format. | ||
Line 57: | Line 65: | ||
A TDoA tag is simply an UWB sniffer. A sniffer can use the data in the packets together with the timestamps when packets are received to calculate its position. | A TDoA tag is simply an UWB sniffer. A sniffer can use the data in the packets together with the timestamps when packets are received to calculate its position. | ||
+ | ===== Calculating TDoA ===== | ||
+ | [[doc: | ||
