doc:lps:tdoa3:protocol [2018-05-02 14:47] kristoffer |
doc:lps:tdoa3:protocol [2020-05-12 14:08] (current) kimberly |
| - | ====== TDoA Anchor protocol V3 (experimental) ====== | ||
| - | <WRAP center round tip 80%> | + | <WRAP center round important 60%> |
| - | **NOTE** | + | This page has deprecated and moved to the new documentation framework of the main Bitcraze website. Please go to [[https:// |
| - | This is work in progress. The specifications on this page may change at any time without backwards compatibility. | + | ====== TDoA Anchor protocol V3 ====== |
| - | ===== System architecture | + | ===== Design goals ===== |
| - | The protocol is designed to be used with a large number of anchors covering a big area. Each anchor has a limited reach and covers only a small area, but by adding more anchors the system | + | The protocol is designed to be used with a large number of anchors covering a big area. Each anchor has a limited reach and covers only a small area, but by adding more anchors the system |
| Each anchor knows its own position in a global coordinate system and broadcasts this information in time stamped packets that are used by one or more Tags to estimate their position. | Each anchor knows its own position in a global coordinate system and broadcasts this information in time stamped packets that are used by one or more Tags to estimate their position. | ||
| Line 18: | Line 16: | ||
| ===== Packet scheduling ===== | ===== Packet scheduling ===== | ||
| - | Packets are transmitted at random times and collisions are handled by the system. | + | Packets are transmitted at random times and collisions are handled by the receiving party. |
| ===== Packet format ===== | ===== Packet format ===== | ||
| - | There is only one packet format. | ||
| Line 62: | Line 58: | ||
| ===== Tag implementation ===== | ===== Tag implementation ===== | ||
| - | A TDoA tag is simply an UWB sniffer. A sniffer can use the data in the packets together with the packet receive | + | A TDoA tag is simply an UWB sniffer. A sniffer can use the data in the packets together with the timestamps |
| + | ===== Calculating TDoA ===== | ||
| + | [[doc: | ||
