doc:lps:toda3 [2018-05-11 15:04] kristoffer created |
doc:lps:toda3 [2018-10-31 18:21] kristoffer |
- | The TDoA3 mode is experimental | + | TDoA 3 is part of the official Crazyflie |
- | To try it out you will have to do the following: | + | The Crazyflie |
+ | If you want to force the Crazyflie | ||
- | ===== The LPS Nodes ===== | + | ==== The LPS Nodes ==== |
- | * Compile | ||
+ | * Set anchor positions, see below. | ||
- | ===== The Crazyflie ===== | + | ===== Setting anchor positions ===== |
+ | Anchor positions can be set by the python client or the tool in the lps-node-firmware repo. | ||
+ | You might have to move the Crazyflie close to all anchors to transfer the positions from the Crazyflie. | ||
+ | ===== Sniffing ===== | ||
+ | If an anchor is configured to act as a sniffer, it can be used to listen to the UWB messages in the system. To set an anchor to sniffer mode, connect via USB and configure it to sniffer mode. | ||
+ | example: '' | ||
+ | Recompile the Crazyflie | ||
+ | For instance '' | ||
+ | Recompile the Crazyflie firmware with the LPS_LONGER_RANGE compile flag. | ||
+ | Example: '' | ||
+ | * Find the src/ | ||
+ | * Compile and flash | ||
+ | * There is a configuration setting for the preamble length | ||
