doc:lps:toda3 [2018-05-11 15:06] kristoffer |
doc:lps:toda3 [2018-06-15 08:42] kristoffer |
Line 3: | Line 3: | ||
<WRAP center round tip 80%> | <WRAP center round tip 80%> | ||
**NOTE** | **NOTE** | ||
- | The TDoA3 mode is experimental and the code is unstable or might not yet work at all | + | The TDoA3 mode is experimental. The protocol |
+ | ===== Compile and flash ===== | ||
To try it out you will have to do the following: | To try it out you will have to do the following: | ||
- | ===== The LPS Nodes ===== | + | ==== The Crazyflie |
- | * Get the latests source code for the firmware from [[https:// | + | |
+ | * Compile for TDoA3 and force the TDoA mode with '' | ||
+ | * Flash the Crazyflie with '' | ||
* Compile | * Compile | ||
* Flash the nodes using '' | * Flash the nodes using '' | ||
+ | * Anchor positions can be set using the python client (0 - 7) but if you have more anchors you will have toools/ | ||
+ | Recompile the Crazyflie firmware using the LPS_2D_POSITION_HEIGHT compile flag set to the desired Z. | ||
+ | For instance '' | ||
+ | Recompile both Crazyflie and anchors with the LPS_LONGER_RANGE compile flag. | ||
+ | Example: '' | ||
+ | * Find the src/ | ||
+ | * Compile and flash | ||
+ | * Find the src/uwb.c file | ||
+ | * Locate the line where PREAMBLE_LENGTH_S is defined | ||
+ | * Change it to 1024 bits: #define PREAMBLE_LENGTH_S ( 1024 * 1017.63e-9 ) | ||
+ | ===== Sniffing ===== | ||
+ | If an anchor is configured to act as a sniffer, it can be used to listen to the UWB messages in the system. To set an anchor to sniffer mode, connect via USB. | ||
+ | example: '' | ||
- | ===== The Crazyflie ===== | ||
