doc:lps:twr-reference-setup [2017-05-17 16:11] macke created |
doc:lps:twr-reference-setup [2018-01-22 16:16] bjorn |
- | In order to illustrate how to set up a system we document a reference system and how we've set it up. The referance system is based on the [[https:// | + | In order to illustrate how to set up a system we document a reference system and how we've set it up. In our reference setup we have placed 3 anchors above and 3 anchors bellow the flight area, shaped in inverse triangles. This allows to get good accuracy in X, Y and Z. |
- | ====== Reference set-up ====== | + | |
This is the reference system from which measurement where taken: | This is the reference system from which measurement where taken: | ||
- | {{:doc:lps:locorefv3.png|}} | + | {{:doc:lps:loco_ref_system_6_anchors.png?1200|}} |
