doc:lps:twr-reference-setup [2018-01-22 16:12] bjorn |
doc:lps:twr-reference-setup [2020-05-12 14:10] (current) kimberly |
| - | ====== Prerequisites ====== | + | <WRAP center round important 60%> |
| - | In order to illustrate how to set up a system we document a reference system and how we've set it up. The referance system is based on the [[https:// | ||
| - | * 6 x Loco positioning node | ||
| - | * 1 x Crazyflie 2.0 | ||
| - | * 1 x Loco positioning deck | ||
| - | * 1 x Crazyradio PA | ||
| - | ====== Reference set-up ====== | + | ====== Reference set-up |
| - | In our reference setup we have placed 3 anchors above and 3 anchors bellow the flight area, shaped in inverse triangles. This allows to get good accuracy in X, Y and Z. | + | This reference system can be used to position in Two-way ranging mode (TWR). |
| - | This is the reference system from which measurement where taken: | ||
| - | {{ :doc:lps:crazyflie_isometric_drawing_2.png?600 |}} | + | ====== Reference set-up using 8 anchors (TDoA/TWR) ====== |
| + | This reference system can be used to position in Two-Way Ranging mode (TWR) and Time Difference of Arrival mode (TDoA). In this reference setup we have placed 4 anchors above and 4 anchors bellow the flight area, shaped like a box. Note the numbering of the anchors, this allows to get good accuracy in X, Y and Z. | ||
| + | {{:doc:lps:loco_ref_system_8.png?1200|}} | ||
| - | ====== Measurements taken from our reference set-up ====== | ||
| - | To validate the system we took a series of measurement from the reference system. You can see the results in the page [[misc: | ||
