misc:hacks:taranisandroid [2015-07-17 00:18] fred |
misc:hacks:taranisandroid [2015-07-17 00:32] fred |
Line 11: | Line 11: | ||
* you need to configure the thrust input (Weight 50% and Offset 50%) | * you need to configure the thrust input (Weight 50% and Offset 50%) | ||
* otherwise you can not use the full travel of the axis assigned to thrust | * otherwise you can not use the full travel of the axis assigned to thrust | ||
- | * Servos menu | + | * Servos menu |
* invert Thrust (CH1) | * invert Thrust (CH1) | ||
* invert Eleron (CH3) | * invert Eleron (CH3) | ||
You can also download the configuration as an EEPE file and install it with the OpenTX Companion application. | You can also download the configuration as an EEPE file and install it with the OpenTX Companion application. |
