If you already own a Taranis X9D (Plus) RC transmitter and want to use it as a controller, it can be configured to work with the Crazyflie Android client.
Fortunately the transmitter is able to act as an USB Joystick (see https://github.com/opentx/opentx/wiki/OpenTX-USB-Joystick).
You should create a new model when using the Taranis as an USB Joystick:
Here are the necessary steps to configure the Crazyflie Android client:
