misc:hacks:taranisandroid [2015-07-17 00:33] fred |
misc:hacks:taranisandroid [2015-07-17 01:04] fred [Create a new model for the Taranis X9D (Plus)] |
Line 6: | Line 6: | ||
===== Create a new model for the Taranis X9D (Plus) ===== | ===== Create a new model for the Taranis X9D (Plus) ===== | ||
- | You should create a new model when using the Taranis as an USB Joystick: | + | [[ https://wiki.bitcraze.io/misc:hacks:taranispython?# |
- | * you can turn off both internal and external TX modules | + | |
- | * you need to configure the thrust input (Weight 50% and Offset 50%) | + | |
- | * otherwise you can not use the full travel of the axis assigned to thrust | + | |
- | * Servos menu | + | |
- | * invert Thrust (CH1) | + | |
- | * invert Eleron (CH3) | + | |
- | {{:misc:hacks:taranis_thrustinput.png?direct& | + | |
- | You can also download | + | |
- | * USB Joystick EEPE file: {{: | + | |
- | * Download the Companion application here: http:// | + | |
===== Configure the Crazyflie Android client ===== | ===== Configure the Crazyflie Android client ===== | ||
Line 45: | Line 27: | ||
===== Use the Taranis X9D (Plus) with the Crazyflie Android client ===== | ===== Use the Taranis X9D (Plus) with the Crazyflie Android client ===== | ||
- | - Before connecting to the Crazyflie, check that all axes are working (values should change) | + | - Before connecting to the Crazyflie, check that all axes are working (values should change |
- **Attention: | - **Attention: | ||
- Connect to the Crazyflie 2 over BLE | - Connect to the Crazyflie 2 over BLE | ||
* If you have a Crazyflie 1 you need to use a (powered) USB hub to connect both the Taranis RC transmitter and the Crazyradio USB dongle | * If you have a Crazyflie 1 you need to use a (powered) USB hub to connect both the Taranis RC transmitter and the Crazyradio USB dongle | ||
+ | - Fly the Crazyflie with the Taranis and have fun! :-D | ||
