misc:hacks:taranisandroid
Using a Taranis X9D (Plus) RC transmitter with the Crazyflie Android client
If you already own a Taranis X9D (Plus) RC transmitter and want to use it as a controller, it can be configured to work with the Crazyflie Android client. Fortunately the transmitter is able to act as an USB Joystick (see https://github.com/opentx/opentx/wiki/OpenTX-USB-Joystick).
Create a new model for the Taranis X9D (Plus)
You should create a new model when using the Taranis as an USB Joystick:
  • you can turn off both internal and external TX modules
  • you need to configure the thrust input (Weight 50% and Offset 50%)
    • otherwise you can not use the full travel of the axis assigned to thrust
  • Servos menu
    • invert Thrust (CH1)
    • invert Eleron (CH3)
 Main screen  Model setup
 Thrust input settings  Servos settings
Configure the Crazyflie Android client
Here are the necessary steps to configure the Crazyflie Android client:
  1. Turn on the Taranis
  2. Connect the Taranis with a USB cable and a USB host (OTG) adapter to the Android device
    • The Taranis screen should display a USB symbol when it's connected
  3. Check that all sticks are in center position
  4. Open the Crazyflie Android client
  5. Go to Preferences → Controller Settings and switch Controller to Gamepad
  6. Go to Gamepad axis and button mapping and configure the following axes
    • Right analog X axis should be AXIS_Y
    • Right analog Y axis should be AXIS_Z
    • Left analog X axis should be AXIS_RX
    • Left analog Y axis should be AXIS_X
  7. Depending on the mode you are using on the Taranis (Mode 1 or 2), set the Mode in the Android app
    • Preferences → Flight control settingsMode
Use the Taranis X9D (Plus) with the Crazyflie Android client
  1. Before connecting to the Crazyflie, check that all axes are working (values should change)
  2. Attention: Always make sure that the thrust stick is all the way down before connecting to the Crazyflie :!:
  3. Connect to the Crazyflie 2 over BLE
    • If you have a Crazyflie 1 you need to use a (powered) USB hub to connect both the Taranis RC transmitter and the Crazyradio USB dongle
misc/hacks/taranisandroid.1437086000.txt.gz · Last modified: 2015-07-17 00:33 by fred
