misc:hacks:taranisandroid [2015-07-16 23:51] fred |
misc:hacks:taranisandroid [2021-06-24 16:46] (current) kimberly |
| - | ====== Using a Taranis | + | <WRAP center round important 60%> |
| + | ====== Using a Taranis | ||
| - | If you already own a Taranis | + | {{ : |
| + | Fortunately the transmitter is able to act as an USB Joystick (see https:// | ||
| - | Fortunately the transmitter is able to act as an USB Joystick (see https:// | + | ===== Create |
| - | * you can turn off both internal and external TX modules | + | [[ https:// |
| - | * you need to configure | + | |
| - | * otherwise you can not use the full travel of the axis assigned to thrust | + | |
| - | * Servos menu | + | |
| - | * invert Thrust (CH1) | + | |
| - | * invert Eleron (CH3) | + | |
| - | You can also download | + | ===== Configure |
| + | Here are the necessary steps to configure the Crazyflie Android client: | ||
| + | - Turn on the Taranis | ||
| + | - Connect the Taranis with a USB cable and a USB host (OTG) adapter to the Android device | ||
| + | * The Taranis screen should display a USB symbol when it's connected | ||
| + | - Check that all sticks are in center position | ||
| + | - Open the Crazyflie Android client | ||
| + | - Go to Preferences -> **Controller Settings** and switch Controller to Gamepad | ||
| + | - Go to **Gamepad axis and button mapping** and configure the following axes | ||
| + | * Right analog X axis should be AXIS_Y | ||
| + | * Right analog Y axis should be AXIS_Z | ||
| + | * Left analog X axis should be AXIS_RX | ||
| + | * Left analog Y axis should be AXIS_X | ||
| + | - Depending on the mode you are using on the Taranis (Mode 1 or 2), set the Mode in the Android app | ||
| + | * Preferences -> **Flight control settings** -> **Mode** | ||
| + | ===== Use the Taranis X9D (Plus) | ||
| + | - Before connecting to the Crazyflie, check that all axes are working (values should change in the Android app) | ||
| + | - **Attention: | ||
| + | - Connect to the Crazyflie 2 over BLE | ||
| + | * If you have a Crazyflie 1 you need to use a (powered) USB hub to connect both the Taranis RC transmitter and the Crazyradio USB dongle | ||
| + | - Fly the Crazyflie with the Taranis and have fun! :-D | ||
| - | * USB Joystick EEPE file: {{: | ||
| - | * Download the Companion application here: http:// | ||
