If you already own a Taranis 9x (Pro) RC transmitter and want to use it as a controller, it can be configured to work with the Crazyflie Android client.
Fortunately the transmitter is able to act as an USB Joystick (see https://github.com/opentx/opentx/wiki/OpenTX-USB-Joystick), but first you need to create a new model for this configuration:
